NeverEnding Quest for Power
Hello everyone
Iva had my car close to 5 years now, Original Color Midori Green (Obviously Repainted) , it was B Series Turbo, spun a bearing and decided to sell everything and Go K Series, Didnt want to Go All Out so i went a piston and Rod Set up, something safe and Fun drive
Head
Complete Supertech Head pakg
(Valves,Springs,Retainers & Keepers)
IPS K10 cams
Skunk 2 Ultra Manifold
Skunk 2 90mm TB
2 Liter plenum
1000cc iD injectors
Precision 67/66 turbo
BWR Sidewinder /60mm Flange
Tial 60mm WG
Bottom End (stock)
K20
Arias 11:1 86mm pistons
Upgraded Wristpins
Eagle Rods
Clevite Racing Bearing
TD Autoworks timing Sproke assembly
New Timing Chain
New Chain Tensioner
Fuel System
Bosch 044 Fuel Pump
Inline Fuel filter
Aeromotive Fuel Regulator
E85
Transmision
6 Speed Type S
OBX 1-4th gears
MFactory LSD
Stock axles
Clutchmasters Twin dics
Suspension
D2 Coilovers
F7 control Arms
Skunk 2 Front Camber kits
Engalls Rear Camber Kit
TE37 in Mag Blue
Nitto NT01
http://uploads.tapatalk-cdn.com/2016...be5c3e63f2.jpg
http://uploads.tapatalk-cdn.com/2016...99ed4bbb57.jpg
http://uploads.tapatalk-cdn.com/2016...3ca110b4fc.jpg
http://uploads.tapatalk-cdn.com/2016...546c6b3e16.jpg
http://uploads.tapatalk-cdn.com/2016...2baf8971c6.jpg
http://uploads.tapatalk-cdn.com/2016...b774a91410.jpg
http://uploads.tapatalk-cdn.com/2016...bfadc9b3af.jpg
http://uploads.tapatalk-cdn.com/2016...72e414acb5.jpg
http://uploads.tapatalk-cdn.com/2016...4740e2418e.jpg
[MENTION=56]PetefromtheStreets[/MENTION]
Thanks for the Seals part Number, Ordered & waiting on delivery to finish up the Tranny and Mount the Motor
So got some time to install a K Tuned Billet Shifter with Stock cables of coarse. ive heard alot from the Ktuned race spec cables so went with the OEM. fabbed up a shroud for the Raditor, Opted for the Ktuned Upper filler neck with fittings to the radiator, gives it a very Cleaner look.
https://uploads.tapatalk-cdn.com/201...c3be8dfc7c.jpghttps://uploads.tapatalk-cdn.com/201...d8f8c6f697.jpg
