Replacing the Knock sensor
So some how my knock sensor went bad and I could not find a DIY to comfort me in my time of need. After looking at it from the top and bottom I decided this was the easiest way to do it.
DTC P0325
Car was sluggish and bogged out under heavy acceleration. Idle was ok but not as it should be. When lightly accelerating it would misfire.
I will assume general knowledge and ability to work on your car and will not be responsible if you break your stuff
Tools:
Towel (to protect paint)
24MM Deep socket (appropriate sized ratchet usually 1/2inch and extension)
**NOTE** you can use an adapter to go from 1/2 to 3/8 ratchet
1/4 10mm socket and 1/4 Ratchet for hidden bolt next to battery
1/4 extension (so you don't rake your knuckles)
1/4 10mm Deep socket (for loosening battery bolt)
Needle-nose pliers (to squeeze clip on starter)
New Knock sensor
Remove Bolts highlighted in Red. Pay attention to the hidden two pointed out by the arrow.
http://i1215.photobucket.com/albums/...or/1_Bolts.jpg
Hidden bolt from behind
http://i1215.photobucket.com/albums/...cksidebolt.jpg
Loosen this bolt so you can move the battery enough to access the "hidden" bolt.
http://i1215.photobucket.com/albums/...atterybolt.jpg
Remove bolt and radiator bracket. You can flex your front fascia just enough to get a ratchet in there SAFELY.
http://i1215.photobucket.com/albums/...rontfascia.jpg
Remove bolts and push this back so it is not on top of rail anymore. You can do this at the same time of removing the whole rail.
http://i1215.photobucket.com/albums/.../5_radmove.jpg
Disconnect fan harness (squeeze plug and pull)
http://i1215.photobucket.com/albums/...disconnect.jpg
You can now remove the rail
http://i1215.photobucket.com/albums/...or/7_moved.jpg
Remove the plug from the knock sensor and then remove the knock sensor
http://i1215.photobucket.com/albums/...8_SensorIN.jpg
New and Old
http://i1215.photobucket.com/albums/...ldnewknock.jpg
Install new knock sensor by hand first! DO NOT USE THE SOCKET YET. Make sure it threads all the way to the block if it doesn't then you are cross threading it. I had trouble getting mine started.
New knock sensor installed
http://i1215.photobucket.com/albums/..._installed.jpg
Now you can reassemble just follow the reverse directions
FIRST!
Push the gray wire clip back in the starter that is securing the wire
Connect wire back to knock sensor
connect fan wire
Make sure the Radiator bracket lines back up. If not then shift your radiator around. Also, do not tighten your bolts down until they are all in. Just get them started.
reinstall bolts
tighten battery back
And anything else I forgot! HEHE
Re: Replacing the Knock sensor
Well, I will be using this to install my new ported & polished intake manifold tomorrow! Made by [MENTION=28]Spaz[/MENTION]. Thanks in advance [MENTION=262]VTECFRED[/MENTION]
Nice! I'll be swapping my IM at the same time, and possibly my fuel return too. So it'll be a few hours at the least. I need a 24mm deep socket and a 1/2" drive tho
I used this for my IM swap. Worked well, I didn't know I'd need a bunch of extra stuff to remove the IM but you live and you learn! Thanks a lot for this [MENTION=262]VTECFRED[/MENTION], your DIY was a great help for me.
Before:
http://img.tapatalk.com/d/13/09/06/4ymage3a.jpg
During:
http://img.tapatalk.com/d/13/09/06/pu8y5u4u.jpg
http://img.tapatalk.com/d/13/09/06/8y5u5una.jpg
After:
http://img.tapatalk.com/d/13/09/06/jydy9e6e.jpg
Behind the scenes photoshoot ;)
http://img.tapatalk.com/d/13/09/06/suvygane.jpg
aLmk
Is it just a painted rbc?
My guess is it was cut open ported and polished up, welded the all welds grind down and shaved and the painted . That's sooo much work lol
aLmk
Visually, shaved and painted. But inside, it's nicely PnP'd.
1SLOWFG2
Yup! Left a liiiittle bit of welding underneath for 'proof' lol.
Live Plants. Peep both the TB and head flange.
http://img.tapatalk.com/d/13/09/07/edydy6yj.jpg
http://img.tapatalk.com/d/13/09/07/jynure9a.jpg
Damn that looks clean! Nice work there! Is that powder coated?
Sent from my SCH-I535 using Tapatalk 2
VTECFRED
It's rattle can'd I believe. I never could get it to work like this guy does.
aLmk
Have a before picture? I've never had my IM off, don't know what it looks like.
Of the inside/runners? I don't, but [MENTION=56]Adm_rsx[/MENTION] can get me pics of the inside of a stock OEM RBC IM :thumb:
VTECFRED
Adm_rsx
What Adam said. It's rattle canned! I love how it came out, im happy with it
