Tranny:
Stock 6 speed with New oem gears treated by racer steve.
Comp stage 5 unsprung clutch
comp flywheel
Turbo:
PLM manifold
Tial 44mm wastegate
Tial BOV
Borg Warner S362 ETT .70 t3 housing
hondata bbg solenoid
precision intercooler with custom 3" ends
xcessive bottom feed intake manifold with extensive porting
Q45 90mm throttle body
dual walbro in take full blown setup
-8 feed -6 return
Bosch 1600cc injectors
aeromotive pressure reg
golden eagle polished fuel rail
-16 AN coolant hoses
Brake line tuck with a wilwood 7/8 master, custom boost delete plate.
Tucked clutch resevior
Full wire tuck
DSS 2.9 axles
All fab work and motor build and tuning done by me out of my garage.
Car is currently running on e85 at 28-30 lbs of boost (fuel system maxed out) making a little under 700.
With boost by gear setup it hooks hard in most gears with a lot less power, im running toyo r888 tires.
03-19-2013
1SLOWFG2
TX2K13: 700whp Cobra vs. 700whp Civic Hatch
Sick man!
03-19-2013
monjarassi
builds like that are so motivating and the thing is that his setup is so simple!!
03-19-2013
1SLOWFG2
Right, and it's amazing what a k-series engine is capable of!
03-19-2013
1BadK
Thanks Martin!! Real good to meet you down there bro. Had a real good time and cant wait to visit again
03-19-2013
monjarassi
:turbosmiley:
03-21-2013
Si Speed 317
Awesome video, great runs, and the setup looks great! What fuel pump(s) does it have? Let's get a build thread up on here. The more I see E85 setups the more excited I am to run it!
03-21-2013
monjarassi
03-30-2013
echo3gulf
omg sick! I wanna go down there so bad but i need more power!
