Hey guys I'm having a serious problem with traction on my 215's at 375whp. How wide of a tire can I run without rubbing? 235?
Are you on stock rims? I fit 235/40/17 on the stock rims just fine and had no traction issues at ~375whp/~260wtq on my old turbo setup. I was using dunlop z1 star specs.
The kind of tire Also makes a big Difference. Seems everyone running the star spec z1 ate having great success. My friend cut a 1.9 60' on then with his srt4. So I'd get a set in what [MENTION=185]aLmk[/MENTION] suggested. I'm running 235/45/17 on stockrims But they are fuzion zri and they spun bad at 330whp. Now even more so. My next set will be the star specs as well.
The z2 star specs replaced the z1s and are even better.
Those should help solve your traction problem!
Depending on how low your are they may run some.
Plus won on the Z2's I might go with 235 on stock. I got 245/40 on 17+35's stock height and no issues.
I was on 235/45/17 Hankooks while lowered with barely a 2-finger gap, & I never rubbed. My camber was also zeroed out.
would you all prefer 40's or 45's? I thought higher the side wall the more grip you would get.
Somewhat. But not in all cases. Tie compound has a play in that as well
s4 IG-petefromthestreets now Free
so a softer compound like BFG Radials stick with a 40
Yea. A 40 series drag radial would yield more grip then a 45 series Street radial or all season tire.
Okay good info... im getting ready to put 225/50/17 on just cause they are free99 complements of honda hope they dont look too monsterous.
I hope they fit.... If you are lowered at all, I imagine you will rub a LOT.
ya i am but i have no problem raising the car up these are just gonna be a temp till i can afford a good set of rims and tires. but the cars going away for winter here in a couple of months any ways.
