5 Attachment(s)
		New guy here! 600whp or bust build
		I've been on the forum for a bit just have not posted a whole lot... I went 10 months on my boost Junkyz kit and stock motor and made 462/300 on 15psi . We are now in the process of doing a sidewinder kit with a comp ct4-6062 an see what kind of power it will make. Ill be running on a stock block and pump gas for the time being , but building my spare motor for big numbers. Ill post a few pictures of the car and I will try to post more as the build progresses but I'm pretty busy right now so stick with me.
List of mods
-one off Boost Junkyz front mount 2 piece turbo manifold
-Boost Junkyz 3" 2 piece downpipe
-Boost Junkyz vertical  flow same side intercooler
-Boost Junkyz wrinkle black powdercoated charge piping
Boost Junkyz catch can/ coolant reservoir
-Comp Turbo ct4-6062 triplex ceramic ball bearing turbo
-2 Tial Mvs 38mm wastegates Black
-Tial Q black blow off valve
- [MENTION=789]VitViper[/MENTION] 4 port boost control solenoid
-aluminum v-band charge piping couplers
-Boost Junkyz hand port and polished intake manifold powdercoated wrinkle black
-tsx hand ported and polished throttle body powdercoated wrinkle black
-Injector Dynamics 1000cc injectors
-Karcepts black fuel rail
-Hondata 4 bar map sensor
-Full-race 3" cat back exhaust full v-band
-Aem digital wideband and boost gauges
-xlr8 dual gauge pod
-Hondata flashpro
-Hondata traction control
- [MENTION=789]VitViper[/MENTION] tuned
-custom powdercoated vented valve cover
-all vacuum lines , catch can lines, fuel lines in black AN fittings and black SS nylon lines
-Walbro 255lph fuel pump
-varrstoen es 2.2.0 17x9+30 wheels on 245/40/17 Bridgestone tires
-Varrstoen neo chrome open ended lug nuts
-skunk2 coilovers
-skunk2 v2 rear camber arms
-pink beaks rear lower tie bar w/ BOOSTED BITCHES sticker
-Hybrid racing full replacement short shifter
-hybrid racing cable bushings
-mtec shift spring
-competition clutch stage 4 clutch
-hasport full replacement mounts
-09 front end conversion
-s2000 push button start
-dual projector retrofit headlights
Attachment 131
Attachment 132
Attachment 133
Attachment 134
Attachment 135
This should be a fun build !
How the garage looks now getting the kit ready to ship out
http://img.tapatalk.com/d/13/02/28/uzuhusa2.jpg
I'm gonna miss this manifold we had lots of good time together lol
http://img.tapatalk.com/d/13/02/28/abejedu7.jpg
Too much shit in here
http://img.tapatalk.com/d/13/02/28/e9arezut.jpg
http://img.tapatalk.com/d/13/02/28/rabu4yra.jpg
http://img.tapatalk.com/d/13/02/28/yre6uhe6.jpg
		Yeah I'm building the motor , wiseco 11:1 compression , Manley turbo tuff rods and yeah ill run dual maps, one on pump and one on race gas. The car is still going to be my WIFE'S daily lol. I guess I should state it's a mainly female driven car. She drives it to work everyday .
snizzletoff
			What are you going to change to get to 600? are you building everything or just going to run race gas? your thread title seems strangely familiar to me LOL
Good luck with the build.
 Do I know you? Lol
snizzletoff
			Sounds like a solid build, pretty crazy that its your wifes DD she must like to go fast!!! :vtec: And nope i don't think i ever talked to you before unless your on 8th civic haha.
 She does like going fast! I am on 8th civic also just not super active anymore lol.
aLmk
			Sub'd. Good luck! Are you going to sleeve the block?
 Nah not on this car , I have 3 k20z3 blocks and a whole other z3 swap and 4 k-trannys so if it pops then ill sleeve a block.  ill make the power on the Dyno but most likely turn it down for street use. Since even at 460 traction was pretty limited lol .
aLmk
			So the one you're building with 11:1 pistons will be stock sleeves?
 Correct , stock z3 spec bored .50 over cylinders
		If I sleeve a block ill do a k24 frank build
boosted_teg
			you could always send your block to that company that does pressed in block guard. I forget their name, but roughly 350 dollars. They remove material and add in about 1+" guard.
 Yeah I would rather spend the extra money and just have it sleeved. I've read that stock sleeved have been good up to 700-750 hp so my measly 600 goal should be ok
		Re: New guy here! 600whp or bust build
My07si
			Nah not on this car , I have 3 k20z3 blocks and a whole other z3 swap and 4 k-trannys so if it pops then ill slap a bitch.  ill make the power on the Dyno but most likely turn it down for street use. Since even at 460 traction was pretty limited lol .
  Glad to see the new build - for your wife! Shes quite lucky, lol. Post more pics! Motors, trannys, etc
aLmk
			Cool. It seems that sleeping and boring the motor to 88mm and keeping near stock compression can make great power.
 Boosted k-series setups are never boring and never sleep. :readtherules:
		4 Attachment(s)
		I have tons of pictures but I moved then all to my computer as my phone was full ill get some up later
		I'm in the process of doing a return fuel system, wire tuck and Ecu relocate to get everything cleared out for my new turbo setup . Ill post some pictures along the way as well.
ksboi
			He means ECU relocate. I will be sending you the AN fitting this weekend or I may just come up and drop it all off. It depends on the warden!!! I got a suprise for you on your bday if you wife dont buy you a supra. [MENTION=208]My07si[/MENTION]
 Your right ecu thanks for the correction....and yeah you have 7 months to think of something nice for my bday
ksboi
			Some egyptian sand lol [MENTION=208]My07si[/MENTION]
 Shoot ill take it
		[MENTION=217]snizzletoff[/MENTION] just got one-upped! Awesome build, in for more!
snizzletoff
			There are lots of civics that have higher HP than me. 550 really isn't THAT extreme for the k20. Making that or more on pump gas will be the challenge. Not to take away from his build but if he uses e85 or race gas than we are in different ball games :wiggle:
:giggle:
 Oh I know, trust me. I was just joking around :cool::thumbup:
		Yeah I'm not here to one up anyone I was just showing what I got going on. This will not be a quick build ill still be on a bone stock motor for the next few months . After my built motor is done I will run a race gas tune to see where we get. But yeah I will be making as much as I can on pump first.
		Yeah what [MENTION=209]ksboi[/MENTION] said I'm thinking of giving it a shot
		http://img.tapatalk.com/d/13/03/05/husugyze.jpg
Picked up mine and a buddy's traction control today can't wait to test it out .
Big thanks to Locash racing for the local in stock hook up!
		Yeah I'm pretty stoked to get my car done now! A little impatient right now lol .. Shop is full and crazy busy
