So I've grown tired of the Iacv just "chillen" in my bay. Looks ugly hanging off my tb.
But even more so on my new s90 tb. No way in hell am I reinstalling that hunk of metal on my new tb.
http://i823.photobucket.com/albums/z...70040A98E3.jpg
So I am a diyer and won't buy a $25 dollar one from ktuned so I thought I'd make my own.
I had a plate of 1/8" or so thick aluminum.
http://i823.photobucket.com/albums/z...62B5A4E246.jpg
Took my old IACV and traced out a pattern.
http://i823.photobucket.com/albums/z...62ADE94624.jpg
Then placed the valve back on my pattern to spot my holes.
And drilled the first hole. Using a .201" bit
http://i823.photobucket.com/albums/z...62AFB4FCD3.jpg
http://i823.photobucket.com/albums/z...62AC0F2CA1.jpg
Then placed the valve back on and put a screw through it and the plate to make my second hole
http://i823.photobucket.com/albums/z...62A9423DA9.jpg
Then put a screw through to make sure the holes were lined up.
http://i823.photobucket.com/albums/z...62A00F33DE.jpg
http://i823.photobucket.com/albums/z...62A2790C27.jpg
After the holes are drilled I took and clamped it down to a table.
http://i823.photobucket.com/albums/z...629E16D81A.jpg
And then cut the piece out using a 4" cutting wheel on my grinder.
http://i823.photobucket.com/albums/z...629C35820D.jpg
Then I took the block off plate to the 6" table grinder to round off my corners and take away the extra material left from cutting
http://i823.photobucket.com/albums/z...629833D24E.jpg
Cleaned up nicely using a flapper wheel on my 4" grinder just taken to the edges to round them off along the part.
Then took and added some swirls in the plate added looks using an air grinder.
http://i823.photobucket.com/albums/z...6288DE9754.jpg
Then my Final touch to shows she's certified...BAM!
http://i823.photobucket.com/albums/z...6282B5F4A4.jpg
Make sure to reuse the oem gasket off the Iacv. For added security I put hondabond around it also to try and make it as air tight as possible for boost.
Along with this mod comes with sacrifice of a smooth idle. This being my racecar I don't care. And I'm tired of lookin at the Iacv.
The throttle blade will have to be propped open further to allow air to the motor since the air can't come through the Iacv anymore.
There is a jam nut to tighten this in stock tb's or in my case with the s90 this screw is the throttle stop.
http://i823.photobucket.com/albums/z...6E65A62229.jpg
Hope this helps anyone looking to do their own or see what it may look like.
