Best Bang-For-Your-Buck Tranny Thread
This thread is about coming up with thr best priced replacement tranny setup for K-series motors, specifically my 06-11 Si K20Z3. One of my goals over the winter is to make a backup tranny for my Si. But, in the process, we'll find out the differences from other K-series chassis and see what fits them too.
So far, I've heard that EP3 5-speed trannys and rsx base 5-speed trannys are the cheapest OEM trannys to get.
Re: Best Bang-For-Your-Buck Tranny Thread
snizzletoff
^that!! To get the Ep3 trans you need to modify 3 or 4 things on the case. Things just don't bolt down the same, the best thing to do is switch the gears. And if you want one hell of a highway MPG queen you can swap in a 6th gear.
to switch the gears into your stock case, you need to get at the minimum a new countershaft bearing, part # 91003-PPT-004 for the 4.3 final drive. Also a good idea to change the transmission baffle as well.
Can you elaborate, go into as much detail as possible?
Thanks for the info guys. What about the rsx 5 speed tranny? I knew literally nothing about the ep3 case situation, in fact I know nothing about this topic. That's why I created this thread.
Does the rsx tranny as a whole swap or is it a gear transfer again? I'm just looking at options
Si Speed 317
The rsx and ep3 both use the k20a3 so its the same trans. Same issues apply to.the rsx 5sp
Sent from my EVO 3D with Tapatalk 2
Good to know, thanks! Gonna start looking into spare trannies. I think Ainokea did a 5 speed swap a couple years ago right?
ksboi
Just swap out the guts in the 5speed and put them into your 6 speed case and keep 6th. I also talked to Jotech and he said for 900 plus shipping he will build you one that holds up to 398tq. That is not bad at all just find a spare tranny and ship it off to get it worked on. I did read a post that he did not tell what he did to it but as long as it holds up to 398tq I think most of us will be fine.
Yea he did my friends tranny. I have confidence in it, as ive been in the car. But I don't like not knowing whats done, ratios, etc. I know he started out with OEM gears from other cars, like the element. But then his stuff disappeared
I talked to him about the trans build they do. They tell you what they do, but the things they told me didn't really make it sounds any stronger. maybe they leave some things out. They also didnt tell me it would hold 350tq though. Also I don't think it comes with a warranty. So it might hold, but who knows for how long.
fre$h si
i remember a while back jeff from go power/skunk2 was saying ppgs were a waste but i forgot the reason as to why.
and is it just me or has anyone else noticed that most race cars have been using oem gears and just replacing them as they break?
but as for me i bought a spare fg2 tranny for a good price and i just have it chillin waiting for the stock one to break
I dont really think you can say they arw a waste. They will hold crazy amounts of power without fail. They are crazy expensive. 4-5k to get the trans done right not including labor if you Cant takle it yourself. Compae that to 90 dollars or so to for a single broken gear..its a big difference and will take a very long time for that to equal 5k. If you buy full gear sets at 300ish it will clearly add up much faster
Most people do just fix the gear that breaks drop your trans 4-5 times a year and you won't wanna keep doing it. You can keep beating ppg's also the ratios are better for high power cars.
I will probably also just get a 5 speed, use a 4.3 final and a 6th gear...but I would say they are far from a waste
BoostedK20
Testing [MENTION=209]ksboi[/MENTION] [MENTION=2]Si Speed 317[/MENTION] [MENTION=56]Adm_rsx[/MENTION] [MENTION=28]Spaz[/MENTION] [MENTION=1]BoostedK20[/MENTION]
Nothing yet man. Idk
Testing the new tag feature ;)
Frana vehicles makes a set. I'm hoping to get a set next year tax time.
