Best Tires for FWD Boosted Setups
Let's face it - even with boost-by-gear/rpm, it's hard to get traction in a high-hp FWD setup in cars weighing less than 3,000 lbs. When I use the word 'traction' I don't mean simply accelerating, but decelerating as well. So, after countless hours of research and productivity, I have come up with the following list of tires to help us achieve the traction we desire. Now, the following is a list that I have compiled myself, along with contributions from many other people's personal experiences. This list will always be updated with new tires, as new products are introduced to the market. So, if you see a tire missing that you believe NEEDS to be on this list, post it up with your experience!
To ensure safe sizing of your future tire setups, here is the handy Wheel and Tire Calculator: http://www.rimsntires.com/specs.jsp
The Best Tires for FWD Boosted Setups
*These are in no particular order*
Summer Tires
1. Nitto NT05
http://www.nicoclub.com/articles/images/nt05.jpg
Very aggressive performance tire with a medium compound. This tire literally fights to keep traction, and provides great traction when driven cold. Provides amazing traction when warmed up! Priced at ~$142 for a 235/40/17, these ares are definitely affordable and a great bang-for-your-buck.
2. Hankook Ventus R-S3
http://www.tirerack.com/images/tires...srs3_ci2_l.jpg
Another aggressive performance tire with medium-hard compound. These were designed for performance street use, however are commonly seen at autocross tracks. And they're properly priced, around $145 a tire for 245/40/17. They provide great traction in dry weather, however if it's less than 40* out, they're useless.
3. Kumho Ecsta XS
http://www.tirerack.com/images/tires...ku36_ci2_l.jpg
The Ecsta Xtreme Street tires are a surprise coming from Kumho. They provide excellent traction in dry weather, and are designed to work well in wet conditions as well. Great tire for a daily driver - traction on the nice days, with great grip on those rainy, cloudy days. They are fairly priced as well, running ~$159ea. for a 245/40/17.
4. Dunlop Direzza Sport Z1 Star Spec
http://www.tirerack.com/images/tires...spec_ci2_l.jpg
These are the tires everyone talks about. They provide superior traction in dry weather without being warmed up, and provide even better traction when warm. And, with a 200 wear rating, these will last for a good while. These tires were designed for lighter cars that have a hard time keeping traction, and are commonly seen on daily driven high hp FWD applications. Nicely priced at ~$175ea. for a 245/40/17, you can't go wrong with these. Don't use these babies in temperatures less than 40* though!
5. Bridgestone Potenza RE-11
http://www.tirerack.com/images/tires...re11_ci2_l.jpg
Designed for grip, these tires won't disappoint the spirited driver that likes to take turns. They work great in dry situations, and are very suitable to wet conditions as well. They come at a price though, ~$244 a tire for a 245/40/17.
Track Tires
All tires listed below are NOT meant for wet conditions with high speed or temperatures below 40*.
1. Yokohama Advan A048
http://www.tirerack.com/images/tires...a048_ci2_l.jpg
Medium-Hard compound tire, 60 wear rating means not too much longevity out of these in a street condition. Great track tire, autocross, circuit, or drag applications. Priced around $278 a tire for a 245/40/17.
2. Nitto NT555R Drag Radial
http://www.discounttirezone.com/asse...tto/nt555r.jpg
A great tire, with unfortunately odd sizing options. Tires are greatly priced, at $170 for a 245/45/17. Only problem is sizing.
3. Nitto NT01
http://www.discounttiredirect.com/pr...nithz8.ang.jpg
Another great tire coming from Nitto - the NT01. At ~$154 for a 235/40/17, these are a great choice for traction! And, with a 100 wear rating, they'll last for a little bit. If you had a choice of drag radials, this is the one to get. One of the best bang-for-your-buck tires available.
4. M&H Racemaster Street and Strip
http://img685.imageshack.us/img685/9734/30056941.jpg
Great drag radial for those running 14, 15, and 16" wheels. Soft compound, made to be driven on the street on the way to the track, not as a daily driven tire. Don't let the look of the tire fool you, the soft compound of this tire makes it a great selection for traction! Typically sold in pairs, tires run ~$167ea for a 235/60/15.
Have great experience with a tire that you don't see listed above? Post it below!!
Re: Best Tires for FWD Boosted Setups
This is the forum! Thanks so much for sharing. I need to look at all of these posts before I ask questions that have been asked before! Thanks again.
Is there anyone running stock sized rims and big HP? Not sure if I'm crazy about running camber to get my rims to fit inside wheel wells.
