marsman328's Sheepey Built DC5 Build
		Greetings :biggrin:
Some of you might know me from ClubRSX (hi)! For those who don't know me, hello. I've been on ClubRSX for years, decided i would finally post up on here.
Enjoy!
Sponsors:
	Continental Tire
	Seibon Carbon Fiber
	NeoChromeParts.com
	DICE Motorsports
	Sheepey Built
Modification List:
Interior:
	OEM DC5 Type-R Recaro Seats, Black suede w/ red stitch
	OEM DC5 Type-R Rear Suede Seats
	OEM DC5 Type-R Honda Badges
	Autopower 4point roll-bar (custom fitted through rear panels)
	Full black interior
	Custom black suede headliner
	S2000 Cluster retrofit
	S2000 push start button with custom carbon panel
	Nardi 330mm black/red stitch steering wheel
	NRG steering wheel release/short hub
	Crow Enterprises Black 3 6 point racing harnesses
	Pioneer Navigation
	JL Audio 4ch/mono Amplifiers & speaker/12sub
	Generic C-pillar Bar
	Hybrid Racing RSX Shifter Box
	Skunk2 Weighted Knob
Exteror/Body:
	Custom pearl white color (BMW Frost/Lexus Pearl)
	Shaved engine bay, with blue flake
	Seibon Carbon Fiber TS Style Hood, Paint matched, showing carbon in vents
	Seibon Carbon Fiber TR Style Spoiler, sides of spoiler paint matched
	OEM A-Spec Front lip
	Type R Front Bumper
	Mugen Style VIS Side Skirts
	Mugen Style VIS Rear Lip (custom molded to rear bumper)
	Custom mounted flush back up camera in 3rd brake light
	OEM DC5 Type R Black Housing HID Headlights
	Password JDM Bumper Quick Release Fasteners (Custom NeoChrome Blue)
	PLX DM-100 Touch & DM-6 (Two) Gauges
	Ortiz Custom Pods
	Dual Center Console Gauge Mount & Single Left Air Vent Mount
Brakes/Suspension:
	AP Racing 4 Piston BBK 330mm (Custom NeoChrome Blue Caliper and Hat)
	Function&Form TypeII Coilovers
	OEM DC5 Type R Sway Bars/Control arms
Wheels/Tires:
	Rays Gram Light 57dr Semi-Gloss Black
	18X9.5 +22/18X9.5 +38
	Continental Tires: Extreme Contact DW
	235/40/18 (front) 225/40/18 (rear)
	Project Kics R40 Iconix Locking Lug Nuts (NeoChrome w/ black centers)
Motor/Performance:
	Hondata K-Pro
	RBC Intake Manifold (CNS Custom Works Shaved and Polished)
	Golden Eagle Fuel Rail
	K-Tuned A/C P/S Delete
	Tucked Clutch Line
	Relocated Fuse Box
	Relocated Battery
	Wireworx  Non-MilSpec Tucked Engine Harness
	Custom ABS Delete Tucked Brake Line Kit (Encore Kit)
	Innovative 75a Billet Mounts w/ steel front mount
	Valve Cover (Custom NeoChrome Blue) with custom All-In Fab Catch Can
	Innovative 75a Billet Mounts (Custom NeoChrome Blue)
	Competech Titanium Front Strut Bar (mounts Custom NeoChrome Blue)
	Downstar Dress Up Washers and bolts (Washers Custom NeoChrome Blue)
	Sheepey Built Turbo Kit,
	Black thermal coated Manifold, DP, Exhaust Housing
	Precision 6062 Gen 2 Ball Bearing Turbo
	Tial 60mm Wastegate/50mm Blow off Valve (Clear Anodized)
	RyWire Tucked Radiator w/ -16 AN fittings
	Jegs -16 AN Blue/Silver Fittings
	Russell Black Nylon Braided Hose w/ blue accents
	K24a2 Block
	Weisco 87.5mm Pistons 8.8:1
	Eagle H-Beam Rods
	OEM Honda Bearings
	Supertech Valves(flat face)/Springs/Retainers
	Black powdered OEM Throttle Body/K-Tuned spacer
	Skunk2 Low profile Valve Cover hardware
	Walbro 400lph Fuel Pump
	Injector Dynamics 1000cc Injectors
	Aeromotive Fuel Pressure Regulator
	Jegs Blue/Silver AN fittings (-8an Feed, -6an Return)
	Russell Black Nylon Braided Hose w/ blue accents (-8an Feed, -6an Return)
	Competition Clutch Stage 4
	Fluidampr Crank Damper
	K-Tuned Oval 3 Catback Exhaust
	K-Tuned K20 Upper coolant housing with filler neck (-16 an fitting)
	K-Tuned K-Series Lower swivel housing with (-16 an & recirculation fitting)
	K-Tuned Coolant Cap
	K-Tuned Billet Throttle Cable/Bracket
	K-Tuned Billet Transmission Bracket
	K-Tuned Coil Pack Cover
The Engine Bay Shave:
http://i24.photobucket.com/albums/c1...ps7kg7akh8.jpg
http://i24.photobucket.com/albums/c1...psp5ggiq9r.jpg
http://i24.photobucket.com/albums/c1...psxqctfxza.jpg
http://i24.photobucket.com/albums/c1...psq1lgo1it.jpg
http://i24.photobucket.com/albums/c1...psly1jaex8.jpg
The Motor:
http://i24.photobucket.com/albums/c1...pskqhftpwi.jpg
http://i24.photobucket.com/albums/c1...pszowckh90.jpg
http://i24.photobucket.com/albums/c1...pssrgpbyno.jpg
http://i24.photobucket.com/albums/c1...pswn3rqb2y.jpg
http://i24.photobucket.com/albums/c1...psjc7hsk6w.jpg
The Sheepey Built Turbo Setup:
http://i24.photobucket.com/albums/c1...psyiwncley.jpg
http://i24.photobucket.com/albums/c1...ps7rcbcwo3.jpg
http://i24.photobucket.com/albums/c1...psg16hljjw.jpg
http://i24.photobucket.com/albums/c1...psxg271cur.jpg
http://i24.photobucket.com/albums/c1...pshkmhqwsg.jpg
http://i24.photobucket.com/albums/c1...pspbj25ps0.jpg
http://i24.photobucket.com/albums/c1...skkhcs1fg.jpeg
http://i24.photobucket.com/albums/c1...sa2kbjamn.jpeg
http://i24.photobucket.com/albums/c1...pscdgiuc1h.jpg
How she sat at SEMA 2015: (yes, i know there is no radiator lol)
http://i24.photobucket.com/albums/c1...psd3f637xz.jpg
http://i24.photobucket.com/albums/c1...pszjzyzkb7.jpg
http://i24.photobucket.com/albums/c1...psc7qldwkr.png
http://i24.photobucket.com/albums/c1...psuhiicpp1.jpg
http://i24.photobucket.com/albums/c1...psaj3kkmlc.jpg
http://i24.photobucket.com/albums/c1...sflhciedx.jpeg
Picked the car up at the body shop on Thursday Oct 29,
Dropped the motor in Friday Oct 30,
Drove to Perris, CA to Sheepey Built and was at the shop 11pm on Oct 31st
Left Sheepey at next afternoon at 4pm after pulling an all nighter.
Rolled into SEMA Monday Nov 1st.
Was a very sped up process to get the car ready for that event, but there is still stuff to do before the car will be ready to run.
The loose ends I need to tie up before she will run are: the Fuel system, the Brake lines, and RyWire tucked radiator and 16 an hoses all have to be installed.
Once that is all together and tight, I will post another update!
Hopefully i will have some numbers to share with you guys within the next few weeks!
Thank to everyone who has been following my build over the years, i finally made it! lol
