Thats my turbo set up. What fmic is that?
Was thinking what would better to run on hotside of turbo .82 or .62? Both will spool to high rpms but the benfit of the faster dpool of .62.
The smaller the A/R on the exhaust side, the quicker the spoolup, but typically less top end flow. A larger A/R on the exhaust side will make for slower spoolup, but more top end flow.
The way it was explained to me was, think of it as blowing air through a straw (small A/R) verses blowing through a 3 inch diameter pipe (larger A/R).
When you blow through the straw, the velocity of the air coming out of the end of the straw will be quite high. However, the straw cannot handle larger amounts of airflow because of its small diameter.
If you were to blow through a 3 inch pipe though, the speed of the air coming out the other end would not be as high. The large diameter of the pipe means it can handle large amounts of airflow.
What are your goals? Log manifold? Custom kit? Probably been posted before but I'm not too active.
Sent from my HTC One using Tapatalk
Match your exhaust housing to rpm characteristics you will be using, compressor map match the motor. /close
