Yup. [MENTION=117]Bottled Morphine[/MENTION] is currently and I will be in a few weeks.
Depends which kit you've got. Ktuned block off plate I'd drill and tap a hole. If your going Davies Craig then I recommend to ktuned thermostat housing.
[MENTION=117]Bottled Morphine[/MENTION] doesn't have a recirculation hose anymore that I'm aware of.
I like this progress! EWP fun
I'm definitely in for one and before end of next session probably a set of bullet proof gears and new syncros. Paint and body is next up after a great set of track coilovers. And...since that three inch pipe hands so low possibly an oval midpipe.
To my knowledge the recirculation hose is there to prevent the head from boiling before the thermostat opens. But with these pumps they flow enough and you don't have a thermostat to cause the issue that you don't need it. Don't quote me unless I'm right.
