the reason i say rod bearing or rod is cuz the night my car f**ed up thats the same noise it made when i pulled over to check that noise,,,,
Gotcha, how can I check those? I know I obviously need to remove the valve cover, do the cams have to come out as well? What do I need to look for there?
Gotcha, well this has been happening a LONG time, like I said about a year and 3 months.... I'd be pretty surprised if it was from a rod bearing and actually lasted this long... What's the easiest way to check that? Drop oil pan?
the lmas yes pull the vc and rotate the cams as if you were doing a valve lash and use a dentist mirror and dig in there and look of the top is missing. Do the same steps for IN and EX
http://i42.tinypic.com/2le4etk.jpg
n for the rod bearing the oil pan has too come off
Ok thanks!
Little update on my goofy noise, it's not an accessory as I removed the belt yesterday, started the car, but be noise was still there. At this point I'm leaning towards a bent or sticky/leaky valve. A very basic test suggested that it could be that and after talking to some people it really doesn't seem to be coming from the bottom end. But I'm gonna get a leak down test done here ASAP. Aside from all this I'm still 80% sure I'll go racing Friday anyway and hope for the best lol since it's been going on so long anyways. After that I'll probably put the car down for a bit and work on getting it actually fixed.
I'm not sure if race on it. Just my $.02. Now that your aware of the issue I'd limp it home and it stay down till the problem is isolated and eliminated
It sucks to stay stranded....
I remember that night it happened to me, Both my wifes phone had no batt and no car charger either!!!
And since i was the first one to surpass everyone that night everybody that stayed behind didnt see me pull off the hwy... And it was 2am.....
