Re: aLmk's 400whp budget build
aLmk
Where did you get those brackets? local hardware store? Get the bolts at same place?
I ask because I plan to get this intercooler by the time the weather warms up and I think I just may buy a boost junkys manifold, downpipe, dumptube, and a t3 GT30 to have some real fun. I'll sell my GT30, tsi, and 3'' downpipe as a package deal.
Come with the kit but are too narrow cut for the bolts so u have to make them a little wider. And just bend them to shape. Works great.
And thats a good idea, works out perfect
aLmk
Thank you!
I hate that the last greddy IC pipe is 60mm, the pipe that connects to the throttle body that is. No one sells 60mm couplers.... 60mm is 2.3622'' so IDK if I should get 2.5 inch coupler or 2.25 inch coupler and IDK what size t bolt clamp to get if I did get the 2.5 inch coupler because it would be a little big...
Get 2.5" coupler, thats what mine is on the charge pipe side. IIRC the oem tb OD is 70mm, so my tb side of the coupler is 2.75". And your t-bolt would be 2.5" because thats the coupler size, they tighten down. If you'd like, you can check the t-bolt desc (or call and ask company) to find out what the t-bolt range is. They should have a range of fully loose diameter and fully tight diameter.
aLmk
So I'm really leaning towards getting boost junkyz manifold/dp/dt and tial wastegate to upgrade my setup. I would keep the greddy IC piping and upgrade to the cxracing intercooler. My question for you guys is what do you think about turbo size? I've been thinking I would want a standard t3 GT3076, but I am thinking maybe a GT3582 would be nice also... Thoughts? I'd like to be able to make near 500 if not right at 500whp on race fuel with the stock motor and I'm not sure if a GT30 will get me there.
I did what you're looking to do. Sold my TSI mani, dp, and gt2871r and got a tubular mani (one-off top mount mani from SRT) and dp with a GT30R and kept my GReddy charge piping. A GT35R, as I was told many many times, is really only beneficial on a built motor setup. On the street, the GT30R allows for a much more useful powerband, vs the GT35R. If you want to hit 500whp on pump 93, iI would recommend a precision 5857. That is ths turbo I would've liked to have gotten, but at the time it was more expensive than a 30R and I couldnt swing it. Str8JDM hit over 500whp on 93 pump with that turbo. But on race gas, you'll hit 500whp for sure with a GT30R. ;)
The gt30r should make for a much better street car. Like speed said a more useable power and. But vdubkilla uses 35r with a huge ar. He made well over 500 on race gas. He also used it to tear up mustangs from lights in OC. So his car did well on the street too. I guess it's about what you want as the end result. Is this a street car? Or a strip car that's driven on the street sometimes.
Nice to see someone else who will upgrade from almost the same setup to pretty much the exact same setup. :thumb:
aLmk
This is a street car that I sometimes drag. But fun street driving is number one priority for me at this point.
A 30r is probably a more accurate turbo for your needs then. My friends putting a 67mm on his rsx. Lol.
aLmk
So what're your guys' thoughts on the efr 7670 vs. 7064?
I like external gates, so I haven't gotten too deep into efr turbos. But I will look into them for you and respond.
P.s. now you have a reason to make an informational article about EFR turbos and why they're so innovative! ;)
How come? All the fab work involved depending on the turbo u go with?
Want to possibly post the exact info youe got, kinda curious
Sent from my EVO 3D with Tapatalk 2
