Dat open diff life is over i see....... lol lol
Finally finished my headlight harness. Deleted ABS and a few other little things and also relocated my fusebox into the passenger airbag slot.
This all came out
http://i18.photobucket.com/albums/b1...616_163342.jpg
This is the finished product
http://i18.photobucket.com/albums/b1...618_111841.jpg
Before
http://i18.photobucket.com/albums/b1...618_103533.jpg
After
http://i18.photobucket.com/albums/b1...618_103550.jpg
I know the electrical tape is ugly. Im hoping it wont be that visible once installed.
Wire delete pile crew checking in :fyea:
http://i1094.photobucket.com/albums/...psb1314295.jpg
sweet, destroying the perfectly Japanese made harness, bye bye
floor harness is super easy. don't know what all you want to remove but keep in mind the factory amp wiring runs through that if you're keeping the radio. You can remove all the wires that goes to the seats. Then you have the abs wires, and then 3 plugs for the evap that will run outside through the trunk. just make sure you don't remove the yellow/blue wire which powers the fuel pump and youre golden
Loving the mini green you have!
Great build thread, very enjoyable! Keep us updated. :thumb:
Mounted intercooler today
http://img.tapatalk.com/d/14/06/25/syme4equ.jpg
And welded a few holes on the firewall shut
http://img.tapatalk.com/d/14/06/25/zy9a7y3e.jpg
http://img.tapatalk.com/d/14/06/25/ugy7ajyg.jpg
Sweeet
Pushing to at least fire it up by my birthday
Dem bird shit ass welds......... :puke:
JK :thefinger: :rotfl: :rotfl:
August 5 lol
Stuff for turbo coolant lines
http://img.tapatalk.com/d/14/06/26/2yda7u4y.jpg
Starting to port the rbc inlet
http://img.tapatalk.com/d/14/06/26/uhygy5av.jpg
To match this
http://img.tapatalk.com/d/14/06/26/ebejuma4.jpg
Is this for use with the GT30?
Yes It is. I for some reason thought the swivel neck was tapped for 1/2" npt but it is also 3/8" npt so I gotta order another fitting
What size is that throttle body? I don't think you will find a restriction with the stock manifold or throttle body with just a GT30. Being that turbo setups blow through the throttle body, it's size is much less relevant than on a blower like a roots style blower that's after the throttle body.
It's just a 70mm. I realize I won't see any noticeable gains from it, I just don't have an oem throttle body and would rather pay the extra $100 to get a new aftermarket one than a used oem one. I'm only port matching the manifold to eliminate turbulence that would occur from charge air coming in a 70mm tb and then hitting a smaller opening in the manifold.
I want the ktuned throttle body now!!!!! Also waiting on their new tps.
that's a nice TB!
Tapped my Rrc brake booster for 1/4" npt
http://img.tapatalk.com/d/14/07/03/6e9u8abu.jpg
stripped the bay for paint
http://img.tapatalk.com/d/14/07/03/e8a6u2eb.jpg
http://img.tapatalk.com/d/14/07/03/nu2erypy.jpg
Picked up my koyo rad with an fittings
http://img.tapatalk.com/d/14/07/03/6arygute.jpg
Sent from my Flying Nimbus Cloud via tapatalk
nice tap job. surprised you didn't go under the manifold
Finally work getting put in lol :rotfl:
Wiring is one thing that I have no patience for, unfortunately. More power to you both [MENTION=867]ryaano18[/MENTION] and [MENTION=1057]Turpid Porpoise[/MENTION] for doing it
