just got new tires lets see how good they hook at the track! hopefully you'll be seeing mid 12's
Nice man. We need to start a thread for 1/4 times.
i need to find a good 1/4 track besides Moroso i cant believe homestead only does it once a month... ****ing fag ass ******s.
What is that manifold/adapter thingy? Is it to the stock header or something? Wierd... but good #s so far!
That's actually the header on R18 motors, there's just a single hole that is used as the exhaust... Not sure why but that's how it is!
Shes been holding up. They produce torque throughout the entire power band, now add boost gotta love it!
Lets see how this R18 performs cause my plans are to :deadhorse::deadhorse: till it pulls the numbers intended ! :beer:
Hahaha that said All work is being done by Jotech Performance (Jo) definitely content with the extra effort they put in to pick up my car!!
Thanks JC!! :clapping: On to the parts! :vtec::vtec:
:beer::beer::beer::beer:
Engine -
*R18A1 Block
*CP Pistons
*Pauter Rods
*ERL Sleeves (Machine Work)
*Custom Head Studs
*SuperTech Custom Retainers
*SuperTech Custom Springs
*ACL Race Bearings
*Injected OEM Mounts (3M Window Weld)
*Custom Intake Manifold - by Gato Performance
*Thermal Gaskets
*GoPower Cam (still debating)
Transmission - (lets see till when it holds!)
*MFactory Helical LSD
*MFactory FD 4.678
*Clutch Masters 'Stage 4' 6 puck clutch
*Stainless Steel Clutch line
*Hybrid Racing Shifter Bushings
*Hybrid Racing Base Bushings
Forced Induction -
*Jotech R18 Turbo Kit
*Precision 5857 Journal Bearing Billet .63 A/R (debating on buying Str8JDM's 5857 BB .82 A/R)
*DEI T3 Turbo Blanket
*Tial 38mm vband
*Tial 50 mm blow off
*Hondata 4bar Map Sensor
*Skunk2 76 mm Exhaust
*Stainless steel Turbo manifold, Downpipe, Dumptube (Ceramic Coated)
*Aluminum 2.5in Intercooler piping
*Aluminum 3' Inch intake with KN filter
*intercooler
***CMB TUNING***
Fuel System -
*255 Walbro Fuel Pump
*Jotech Fuel Return Kit
*Fuel Injecter Clinic 1000cc Injectors
*All fittings will be AN and Stainless steel Braided lines
Suspension/Brakes -
*Skunk2 Pro-C Coilovers (8k Front, 12k Rear)
*Full-Race Traction Balls
*Goodridge Stainless Steel Brake Lines
*ARP Extended Studs
*Hawk HPS Front
http://img9.imageshack.us/img9/7828/img0505r.jpg
Looks like it should be pretty insane :thumb: Expected power/goals?
400+ wtq or BUST! hahahah
