Sweet, the water lines would have came out the hard line that came out the thermostat housing.
It would've had 2 ports for coolant.
Hmm. So I need to buy the k tuned thermostat housing? No way to make it work with stock thermostat housing huh?
Hmm actually looks like the k tuned won't help at all and doesn't have a location for the heater hose to the upper radiator housing..
How would one hook those up.. it's two hoses. So I'm guessing one in and one out...
Yea.. just figure it's gotta be there for a reason so I might as well run it how it was intended for warranty and reliability sake..
I have my coolant lines tapped into my throttle body coolant lines, you really can tap anywhere as long as you don't screw up the flow of the coolant around the car. Doesn't matter which side of the turbo is the feed, just an in and out.
I would definitely run them, turbo was designed for them to be in place, and it allows you to never need to let the car idle before shutting off, it's nice.
I have a quick question and was wanting the opinion from some of the turbo gurus. What wastegate spring pressure do you most use and what would be best for 550 whp on pump and 750whp on c16?
http://i1015.photobucket.com/albums/...psfpeghcbb.png
