Update (copy and pasting again from 8th):
Yea pretty upset about this because I know it's my fault with the grounds. His response to my last question was a can of gas and a match. So I'm not sure of there is much more to test at this point other than replace the ecu which sucks because that means I need to send my flashpro off to hondata and wait to get it back from them.
Yea I know. He hasn't said I need to replace it yet. And he doesn't want to say the ecu is dead exactly because of that. But it appears all tests lead to nothing is wrong other than ecu is undetectable and cannot be communicated with.Quote:
Originally Posted by snizzletoff
You guys have any more thoughts as to what to check out? I assume since it did start the one time fuel pump isn't bad and ecu probably isn't bad. Maybe I just need to keep waiting a few days and spend a lot of money and the issue will just work itself out for no tangible reason.
Pretty sure he has checked/tested all of this.Quote:
Originally Posted by paulom
All fuses are correct. Now as for the ecu being burnt how can you tell if you remove it? I have a feeling that's not the case though as the car started yesterday for 2 seconds.Quote:
I do but idk how that would make me be able to communicate with the ecu.Quote:
Originally Posted by Steve42790
I thought it only didn't detect the ecu when he had the fuse pulled out. Ryan, can you clarify please?Quote:
It's possible but I thought he could detect his ecu the whole time until he pulled out the tap a fuse he was using for his new powe line to the fuel pumps.Quote:
I did think of. I called then earlier but the message on the phone said I needed serial number and ecu number and all that do I hung up. But called back later and just said **** it I don't care of they want that info I just need to know if they can check it. They said they can yadayada and I will need serial no. and stuff to get an RMA number. I just got off be phone with bill and he has one last thing to do to test everything. He has created a new ground wire for the battery. He will have battery grounded to the body and to the block. No grounds are being stacked. The wireloom thing is grounded to frame rail by itself. He is doing this to ensure everything has a good ground. If this yields nothing the only option is to send it to hondata to see what they say. He has checked everything else, power is everywhere its supposed to be, all fuses are fine, etc... Unless anyone else has any suggestions I will be sending the ecu to hondata if this last bit of testing yields nothing.Quote:
Hondata suggested to do that on the phone so I think he's doing it right. Basically he is ensuring the motor is grounded properly.Quote:
Originally Posted by SiDanny
At least that is how I understood what he said on he phone. He asked if the battery had been grounded to the block and that to the frame rail. I just called hondata back to double check and clarify but he didn't answer. I don't understand why you would want the battery grounded at both spots since stock it is grounded only on the frame rail. I don't understand all this electrical stuff that well.Quote:
Ya I agree with you, but I just called hondata again and the guy answered this time. I explained the test to him and he said that was a good way to test.Quote:
I don't think that would tell me anything since I don't think it's the flashpro itself that is broken because be cannot detect the ecu with any of his normal scanners.Quote:
Originally Posted by dil2502
LOL you can't because the ecu cannot be detected. I tried to with a laptop and it said to key on the ignition, but it was already keyed on.Quote:
I don't think he has tried to reflash the car. I imagine he tests things and then sees if his scanner detects the ecu.Quote:
Before we send it off I will make sure he has tested with flashpro as well. Although I doubt that will matter since a regular scanner would be able to detect it as well and the fuel pump would prime and all that jazz.Quote:
The ecu is beyond recovery mode. It is undetectable. When the ecu is in recovery mode flashpro hooked up to a laptop tells you that. In my case it tells me ecu is not detected even with ignition switched to on. Yes everything is updated.Quote:
Originally Posted by mucter
Last test came up with nothing. Will be sending ecu to hondata.Quote:
Don't really know any other local si owners but one and I already have an RMA. Blah blah.... It better be the ecu...Quote:
On the phone they said it will be worked on the day it arrives and next day aired to me.Quote:
You guys are right. I'm going to try to have it tested locally before sending it off.
Alright so to do this properly, should I disconnect his battery? Take out his ecu put mine in. Reconnect battery, then put his key in the ignition put to on and see if my flashpro detects it?
Thanks.Quote:
Just a little update:
When I picked up the ecu and flashpro yesterday afternoon I talked to Bill in some more detail about what he did, and he basically did everything. Checked every fuse again, check all the wires for power when the should have them. He also checked everything with basically every different way you could have the stuff grounded. The last test, the battery was grounded to the frame and to the motor, the motor was grounded to the frame through the mount as stock. The multi wireloom was grounded by itself to the frame. Basically every test he has done says everything has power when and where it should and that everything is perfectly fine except he can still not communicate with ecu. The only thing to really conclude from this is that the ecu has gone bad, this is pretty surprising, but if that's not the case, then I/we have no idea what the problem is.
I was able to get in touch with another local Si owner that I hadn't talked to in a while and thankfully he was willing to help. He is going to swing over here in about an hour and we are gonna swap my ecu in real quick see if my flashpro can detect it in his car, hopefully it will not detect it so the problem is confirmed and there is a tangible fix. Will keep you guys posted.
