I don't suggest this at all... it defeats the purpose of the return line being the feed is so small. By running a larger return line you, for lack of better words, complete the fuel system loop... if you are going to pump a LOT of gas to the injectors using a -8an line feed you need to equally be able to return the flow of unused gas back with at least a -6an or else you'll just back up the pressure and defeat the purpose of your return line fuel system. Using a better return line will help relieve pressure from your fuel pump, keep more gas to it, and decrease injector duty cycle
