So far is looking good
Thanks pal
New, bigger injectors on and ready to roll
http://farm9.staticflickr.com/8239/8...32782041_c.jpg
Another weekend came and more work was done to the harness!! Thanks again to the homie Ryan for the work he put in...
The following sensors were re loomed:
Map, TPS, IAT, and boost solenoid
More to come..
http://farm9.staticflickr.com/8391/8...fd01b60e_c.jpg
http://farm9.staticflickr.com/8383/8...2ee2c82b_c.jpg
http://farm9.staticflickr.com/8402/8...de73209b_c.jpg
http://farm9.staticflickr.com/8239/8...c519dd05_c.jpg
http://farm9.staticflickr.com/8395/8...67997345_c.jpg
http://farm9.staticflickr.com/8113/8...462284d5_c.jpg
http://farm9.staticflickr.com/8126/8...25025621_c.jpg
http://farm9.staticflickr.com/8528/8...222da4e7_c.jpg
Everything looks great! Are you considering moving to a 4 port boost control solenoid?
:confused: how did a boost control solenoid cause his head to lift?
I don't think it was either error, just that his head gasket possibly failed and/or he needs to torque his head studs more. Vit had the same problem on his motor and torquing the head studs more and a cosworth head gasket fixed it. The 4 port works in the same was as the 3 port in that if it fails or is turned off, you run right off the wastegate.
