Just a little playing around with my son in the car. Obviously wouldn't act up too much with him in the car tho.
s4 petefromthestreets
Ya I just have an FX350, and I adjusted it so it would move as much fluid as possible to get the clutch to disengage as much as possible. I know the clutch master clutches advertise they have easy pressure plates, hopefully I'm OK because I like that I am disengaging the clutch more now, the shifts are smoother.
Sure thing...
I ordered the 75 series tilton cmc. 3/4" bore. -$89 from summit racing
The 72-001 adapter from tilton adapts the cmc to fit hondas. - $106 from tilton
The tilton flow control valve- $165 from summit racing
A 48" stainless braided 3an line (I used the line that had straight fittings on both sides) -$30 from summit racing
A m10x1.0 to 3an fitting to go into your slave cylinder. -$10-13 from
http://www.racerpartswholesale.com
3an hose clamps for routing. -$9 for 25 pack from mcmaster.com
Got some super blue brake fluid as well
From http://www.racerpartswholesale.com
What stage clutch an what brand are you running? Just curious on the amount of force it takes to push?
Post some fancy pics
