but really, what would you charge me for these things! Id rather have someone who knows what they are doing do it. I dont trust myself.
lol I understand. Honestly, it all depends on how far you want to go with the first 2. An s2k cluster wiring is just a jumper so its only one option.
for the engine harness, raychem? techflex? mil spec plug? contrawinding? breakout boots? extra connectors for sensors (boost solenoid, aem gauges)?
or just a cleanup job with techflex and everything stays the same? Over valve cover or factory routing?
for the headlight harness, same questions as above but... ac, abs, fan switch, or srs? also where do you want your fusebox (this is the most important part)
you can pm with exactly what you're looking for and we can talk.
Like I said on instagram, ill give a good deal to any bk20 members.
Works for me, my motor is still out of my car so i really cant make a engine harness at this precise moment since i have no way of taking measurements. By the then i should have my motor in and ready to roll with building a harnesss. S2k harness is whenever you are ready I can whip one up
Right?!! its even better when you dont have abs because thats a lot wires you get to remove
Im working on an 05-06 AP2 cluster swap right now for a friend of mine. Found out that you don't need a speedohealer which makes it a little better
