The gate threads are not tapered. You are not supposed to use thread sealant on them. After some discussion on 8th I am going to try the 3 washers as seen in the last picture. The fitting tightened down nicely I think it will work.
Just to let you know, none of the threads on the Tial MVR or MVS gates is tapered. You can thread in 1/8 NPT, but that is not the correct thread pitch, it can damage the threads, and in my case I think is the reason my gate ended up leaking. The previous owner used 1/8NPT to AN fittings on the gate and now the gate leaks where the 2 actuator halves mate, but right by the fittings. Bill is suspecting that threading the NPT fittings in too tight could have caused a small crack which is now causing the leak. And as for using thread sealant on non tapered fittings, this came from my build thread on 8th:
Originally Posted by mucter
Interesting. My thought process is that the sealant creates a 'seal' so no gas or liquid can escape. Don't see why it wouldn't work. I guess we'll see how it goes, one way to find out! If you want the washers to work, I would use crush washers vs regular washers. That would make a difference in my mind, but who knows. [MENTION=28]Spaz[/MENTION] [MENTION=56]Adm_rsx[/MENTION]
Yes it does create a seal, but it creates a seal because it becomes pressurized because of the taper. As you thread the NPT fitting in, its diameter is slightly increasing so it starts slowly adding pressure, that's why you can never 'fully' tighten NPT fittings. And I am using crush washers. The M10x1.0 to 4AN fittings came with a crush washer to seal for liquid/air and the 2 additional washers I used on the bottom fitting are from the banjo bolt fittings that came with the wastegate. When I get home from class tonight I am going to install it and we will know for sure if it works! I hope it does because I really don't want to take it out again, and I really don't want to use rubber lines with the banjo fittings.
Can you just cut off a portion of the threads to make it shorter?
Oh man that's crazy! Glad you found it!
