New guy here! 600whp or bust build
My car was at the shop, it's at my house to do all the wiring, and plumbing.
Same intercooler but 3.5" thick instead of 3"
Wiring is not all supported, not sure if your talking about my headlight harness, or the battery cables?
aLmk
Ok did you delete the AC cooler that sits in front of the radiator? I was messing with my piping today to get better clearance in my wheel well, so I had my bumper off and I was looking at mine at comparing it to your picture. I'm just curious how you got 2, 2.5'' pipes to fit in that spot right off the intercooler. I can see you removed the plastic shield thing, but even with that gone I'm not sure there would be a whole lot of room. Tough to tell in that photo if the AC cooler thing (sorry don't know technical name) is there.
Gotcha, makes sense.
And I was able to get a bit more clearance in my wheel well, and my wheel was not hitting the fender liner on a full right turn, I just hope it also has enough clearance for 15x8 wheels with 24.5x85 slicks.
No the a/c condenser is still there, after the plastic was removed I ground out the corner sheet metal and then capped and welded a plate over the ground down part of the core support for support . Hard to explain but ill see if I can find the pictures I took with my dslr .
Yeah I had to and am still doing a bunch of modifying to make this thing work lol, should be pretty cool when it's all said and done!
