That's so down to make some crazy track grip stuff outta your garage haha.
So anyone goin to any runs this weekend?
Not me, I'll be working all weekend and I need an oil change. You?
I need to change my oil and replace that dumb gasket on my oil return line. Yall should try this I am. It replaces that dumb gasket for the oil return line. I am going to get it and put some locktite on the bolts and torque that hoe down!
I like the 1 piece one like that cus my fitting I had to screw in to the flange was freakin leaking -__-
What do u busy use to cool down your motor between or before runs? I've been just getting a jug filled with ice water and pourin it over my Rbc, thinking bout maybe dry ice? Any suggestions?
Run meth and will not have too. Are you SC?
Just playing around with my slipping clutch until my twin disc gets here
You will notice the RPM stops climbing for a second but I can still pull on a mustang and camero :)
Nice runs Fred! Ksboi, locktite won't work IIRC it gets too hot! And Fre$h, it definitely gets really hot, for sure!
for the guys that run slicks... how much spin do you get with them off a launch? trying to decide between slicks and hondata TC. one of the guys at go power said the TC unit sucks balls and from other reviews ive seen it kinda seems as if there is alot of room for error depending on climate n all that. not to mention slicks r probally cheaper so im deffinatly leaning towards that
^ Dude you're reading my mind :) ^
So anyone running slicks want to chime in?
