I don't want to cause a stir. But ill be on the look out on his fs items and warn the public if I feel they need to know individually.
On a side note, dropped off crank @ the machine shop n the machinist was like wow you got a new crank that fast.
He doesn't know that you work fast lol. How's the shifter setup coming along
Sneak peak of an OEM box i scored from my homie for test fitting purposes only!
Work needs to be done indeed.
http://farm4.staticflickr.com/3737/1...e30f6cf4_z.jpg
http://farm4.staticflickr.com/3693/1...20a25879_z.jpg
Can't wait for the final results man. Gonna be very unique! Keep it up :thumb:
Finally got around to finish off the fuse box re re-locate and had the 3 needed clips rewired and loomed!!
Also mounted radiator and had to re position the FMIC due to fitment with radiator. Overall its coming along nicely..
http://farm6.staticflickr.com/5489/1...d854630c_c.jpg
http://farm4.staticflickr.com/3796/1...d40869f9_c.jpg
http://farm4.staticflickr.com/3673/1...af60d4d3_c.jpg
http://farm8.staticflickr.com/7355/1...a3666931_c.jpg
http://farm6.staticflickr.com/5495/1...18679a62_c.jpg
Got the call i been waiting for, machine shop was done and ready to give back my stuff.
The shop met my expectations and had a fast turn around, would've been faster if the crank situation hadn't happened.
For any locals in need of machine work, no matter how big or small the job might be, i highly recommend them to you.
Westside Performance & Machine
9100 Emnora Ln, Houston, TX 77080
(713) 465-7996
I had them do the following:
Bore the crank .5 over
Hot tank it
Polish & balance crankshaft (with Flywheel & PP)
Resurface flywheel
Now onto the pix!!
http://farm8.staticflickr.com/7370/1...99755f40_c.jpg
http://farm4.staticflickr.com/3791/1...71d369a7_c.jpg
http://farm4.staticflickr.com/3776/1...52ecf097_c.jpg
http://farm6.staticflickr.com/5496/1...19f5b158_c.jpg
http://farm8.staticflickr.com/7351/1...70255729_c.jpg
http://farm8.staticflickr.com/7412/1...6588856e_c.jpg
http://farm6.staticflickr.com/5510/1...60ac6b19_c.jpg
http://farm4.staticflickr.com/3823/1...cb3ae20d_c.jpg
GE oil squirter block off plugs installed
http://farm3.staticflickr.com/2881/1...d879574c_c.jpg
Looks like they did amazing work! As for the oil squirter block-offs, what is the benefit of that?
Maintains higher system oil pressure- a big must for high hp motors.
Monj- were you running the stock z3 oil pump when you grenaded the motor?
Does everyone block off the squirrels? From what I've read/heard about them they can be life savers.
