Here is a DIY on how I made a boost leak tester for my Turbo it has a 4" inlet .
Go to a local hardware/plumbing store and get these items:
3" PVC Female Adapter
http://i540.photobucket.com/albums/g...ps8de834ce.jpg
3" PVC Cleanout Plug
http://i540.photobucket.com/albums/g...psd38e5237.jpg
Fitting of your choice depends how you wanna set it up the top fitting makes no sense so I would NOT get one of those I'd chose one of the bottom 2 choices in the pic.
http://i540.photobucket.com/albums/g...ps3829a8fd.jpg
Air Regulator and the proper fitting for your air connection and the fittings to hook it to your air system or the pvc cap whichever you chose.Your compressor may already have an adjustable regulator so you may not need to purchase one.
http://i540.photobucket.com/albums/g...ps69a5ce8c.jpg
4" coupler to go on the turbo I already have one on mine so I didn't need to buy one.
http://i540.photobucket.com/albums/g...ps1de1ad81.jpg
Ok here goes
1- Drill the pvc cap
http://i540.photobucket.com/albums/g...ps42e83e34.jpg
Select the fitting you wanna use and thread it into the cap I was able to simply clamp the fitting in the vise and press down on the cap pretty good rotate the cap onto the fitting threading it in.
http://i540.photobucket.com/albums/g...ps4a21a763.jpg
I found an old hose in my tool box from an old compression tester so I cut the end off and put it on the barb and clamped it and then threaded the two pvc pieces together , this is what you end up with.
http://i540.photobucket.com/albums/g...psae5c128f.jpg
Most boost leak testers are done like so with an air fitting in the end but since I had the old compression tester hose I did mine differently. Its up to you which connection you put in the pvc cap.
http://i540.photobucket.com/albums/g...psccaf457a.jpg
Then adjust the regulator to the desired psi and install the tester into you turbo inlet and clamp the coupler down on the tool.
http://i540.photobucket.com/albums/g...psc999fa28.jpg
Then hook your air line to your fitting on the boost tester .I didn't use the regulator I posted earlier . I actually used the regulator from my mac tools leak down tester
http://i540.photobucket.com/albums/g...ps05ac31c7.jpg
Now with the system pressurized have fun finding the leaks I have found 3 leaks since making the tool .Thanks to my push leak fittings oh I mean push lock fittings :biggrin:
