2001 Integra JDM front K20a2 6265 turbo
Throwing the idea up to buy another car and the money off my car would pay for a nice turbo kit.
2001 Acura Integra SE
http://jdmstyle.ca/showthread.php?t=4598
http://www.boostedk20.com/forums/sho...65-turbo-build
Engine
k20a2 87mm bore 10:1 wiseco pistons
eagle rods
OEM bearings
OEM headgasket
ARP headstuds
z1 type r cams
HPT chain guide
new oem tensioner
Polished RBC manifold
Ktuned TB adapter
ID1000s
Ktuned FPR/fuel rail
Hondaata boost solenoid with push lock fittings
Modded walbroh 255 pump with seperate relay wired direct
Ktuned passenger side radiator/ coolan hoses
Wire tuck with custom accord quick connect
Kpro
Ktuned shifter plate
Base RSX 5 speed tranny
ACT 6 puck/heavy duty clutch
Ktuned clutch line
Relocated brake proprtional valve
Turbo kit
DB fab sidewinder with entension adapter
Precision bb 6265 .82 exaust polished
Tial 44mm wastegate with 10psi spring
Tial 50mm BOV
3" cold side intercooler piping
2.5" hot side intercooler piping
Threadstone massive 1001hp intercooler
3" downpipe vband wrapped in titanium DEI wrap
2.5" apexi n1 catback exaust
OEM wideband
AEM wideband
Interior
ITR cluster
ITR climate control
ITR rear seats
Battery relocated in trunk OPtima red top
Alpine deck with ipod
Clarion 6.5" components NEW
MTX 6.5 coaxials NEW
exterior
Full oem metal JDM front conversion
Radiator support shaved
License plate bracket shaved
black housed ITR headlights with s2k hid/ballasts
VIS CF hood
VIS CF Trunk
Suspension
Skunk 2 drag coilovers
Skunk2 struts
Skunk2 upper control arms
DGR black lugnuts
rota circuit 8 rims 216/45/16 exsta xs tires in front, 20545/16 in rear
Im sure theres some more.
Car made 443 and 300 trq spinning on the dyno and trapped 126mph at the track. I got TONS of pictures of the build.
This is a 10 year old car, so its not mint. Its daily driven, only in summer. stored in winter.
Theres some exterior work that needs to be done, but nothing crazy. i reflected the price accordingly.
12,500 firm
Try building a JDM front, semi build k20a2 6265 turbod car :P The swap and turbo kit almost cost that amount alone.
