well long story short, ive been tinkering around with my k20 6265 build, trying to get it to run correctly. everything checked out in kpro, no error codes, but my map seems to be f'ed up.
cranking to start the car, map sensor reads 40+psi. wires are hooked up right, i did continuity check from each wire at the sensor to the ecu. Checked for 5v between power and ground.
i slap on a stock map sensor and voila starts. (yes i switched map sensors in krpo each time)
so dunno, waste of money for a sensor?
