*****Video Links of 812hp Avant*****
Ran 10.400@139 at 30psi (675whp) - 39psi makes 812whp/734wtq. Got booted for no cage again and havn't been back to the track.
******Parts List*****
AAA VR6 Engine
- P+P head
- Fresh valve job + Stem seals
- Ferrea +1 mm Superalloy Int/Exh Valves
- Ferrea dual valve Springs and Ti Retainers
- Schrick 268 cams
- Int Engineering rods w/rifle drilling
- ARP Upgraded 625+ Custom Aged 3/8" Rod Bolts
- JE 83mm pistons w/ Upgraded tool steel wrist pins
- Calico coated race bearings
- ARP Head Studs
- ARP Main Studs
Fuel
- Injector Dynamics ID1600 fuel injectors
- 034 Motorsport fuel rail
- 2x Bosch 044 fuel pumps with IntEngineering pump rail
- #8 Fuel feed line, #6 fuel return line
- E85 safe stainless fuel filter -- 100 Micron
- Aeromotive Adjustable FPR
Turbo Stuff
- Precision Ball bearing 6766 turbo
- Kinetic Exhaust Manifold
- Tial 44mm Wastegate
- #4 feed #10 return lines
- Custom 3.5" downpipe
- Custom 3" exhaust -- 22" and 14" magnaflows
- EBC Controlled by ECU w/ stainless fittings + pushloc line
- 2.5" hotside and 3" coldside piping - all t-bolt clamps
- 5" Cobrahead intake with 6" x 10" K&N filter
- Treadstone TR-1045 FMIC
Electronics
- Autronic SM4 Standalone ECU
- Autronic 500R CDI Ignition box
- Upgraded Ford v6 coilpack powered by Autronic 500R
Swap parts
- Custom 1-off intake manifold
- BBK Mustang 75mm throttle body
- Custom engine mount brackets
- OEM Oil Pan
- OEM Adapter Plate
- 034 Starter
- 16" Spal Fan
- New radiator
Drivertrain/Brakes/Suspension
- 01e with PAR engineering Straight Cut Dog Gears - 1+2
- RS4 3+4th
- New OEM syncros on 3/4/5th
- Ratios - 2.82, 1.84, 1.32, 1.034, - stock s4 5th and 6th.
- Clutchmasters FX850 clutch - New disks + T/O
- USP Stainless steel clutch slave + Line
- Stern Engine/Trans mounts
- Stern Power Ring
- Reinforced clutch arm/fork
- 034 Billet rear diff brace
- S4 brakes
- Solid front axles
- K-Sport coilovers
Interior:
- 144k S4 cluster with ALL PIXELS! - (Actual mileage 123k on car)
- RS4 door pulls
- S4 white/grey power Alcantara
- Boost + Oil Press gauge
Exterior:
- RS4 Bumper
- S4 Rear Bumper
- S4 lower doors/skirts
- Rota Grids 18x9.5 -- ET20 + ET38
- RS4 grill
- E-codes w/ HID's
