Threads 1 to 20 of 31
Forum: HELP!! Technical Problems & Chat
Got a problem you can't figure out? Ask and discuss it here!
  1. Intake manifold
    Started by Shanket, 04-05-2015
    05-11-2015 Go to last post
  2. Low Boost Problem
    Started by Brezno, 06-13-2014
    04-04-2015 Go to last post
  3. JDM K20Z2 Motor Questions
    Started by nomad, 10-10-2014
    12-13-2014 Go to last post
    11-26-2013 Go to last post
  4. P0606 PCM failure
    Started by Lilwhit14, 10-16-2013
    11-09-2013 Go to last post
  5. Oil feed suggestions
    Started by Lilwhit14, 10-29-2013
    10-30-2013 Go to last post
  6. What Oil Weight Are You Using?
    Started by Si Speed 317, 04-07-2011
  7. Exclamation Need trans help!!!!!
    Started by froggyfredd, 10-12-2013
    10-17-2013 Go to last post
    07-20-2013 Go to last post
  8. Boosting issue
    Started by 06_typeS, 03-27-2013
    06-15-2013 Go to last post
  9. Weird Brake Noise - Clicking
    Started by Si Speed 317, 05-12-2013
    05-22-2013 Go to last post
  10. Loud bang from suspension
    Started by Jay Si, 04-28-2013
    04-29-2013 Go to last post
  11. Do not like to start
    Started by ksboi, 03-19-2013
    03-21-2013 Go to last post
  12. Replacing Pulleys
    Started by Si Speed 317, 01-29-2013
    01-30-2013 Go to last post
  13. 02-04 rsx with 05-06
    Started by PetefromtheStreets, 11-14-2012
    11-15-2012 Go to last post
    10-12-2012 Go to last post
    09-01-2012 Go to last post
  14. Bov bad?
    Started by carlos K20T, 05-20-2012
    05-25-2012 Go to last post
Forum Information and Options
Moderators of this Forum
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
