Threads 1 to 15 of 15
Forum: Engine
Post your DIY/How-to in the appropriate section of this sub-forum. If your aren't sure where to post your thread, just post it in the general DIY Shop forum and PM a moderator.
    02-17-2014 Go to last post
  1. Sticky Thread Sticky: DIY: Idle Air Assist Valve Delete
    Started by monjarassi, 11-25-2013
    11-26-2013 Go to last post
  1. DIY: Shaving RBC intake manifold
    Started by Spaz, 03-27-2012
    01-07-2018 Go to last post
    09-06-2014 Go to last post
  2. DIY Fender liner Replacement option..
    Started by Spaz, 04-03-2014
    04-03-2014 Go to last post
  3. DIY - Valve Lash
    Started by PetefromtheStreets, 02-20-2014
    02-20-2014 Go to last post
    01-05-2014 Go to last post
    10-07-2013 Go to last post
  4. Cool Honda/Acura Part Number List
    Started by monjarassi, 09-22-2013
    09-22-2013 Go to last post
  5. Replacing the Knock sensor
    Started by VTECFRED, 07-30-2012
    dtc, knock sensor, p0325, po325
    09-10-2013 Go to last post
    09-08-2013 Go to last post
  6. DIY- IACV delete plate
    Started by PetefromtheStreets, 01-30-2013
    01-31-2013 Go to last post
  7. How to time your motor
    Started by snizzletoff, 10-02-2012
    10-02-2012 Go to last post
    03-01-2012 Go to last post
  8. DIY Valve Adjustments
    Started by Spaz, 04-06-2011
    04-06-2011 Go to last post
  9. DIY Compression Testing your engine
Forum Information and Options
Moderators of this Forum
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
