Threads 1 to 13 of 13
Forum: Engine
Both internal and external engine-related discussion - from water pumps to pistons and everything in between!
  1. Sticky Thread Sticky: How To Use Plastigage -EricTheCarGuy
    Started by monjarassi, 04-16-2014
    04-16-2014 Go to last post
  2. Sticky Thread Sticky: Regular oil vs Synthetic oil- EricTheCarGuy
    Started by monjarassi, 02-14-2014
    02-15-2014 Go to last post
  3. Sticky Thread Sticky: Understanding oil pressure - EricTheCarGuy
  4. Sticky Thread Sticky: How to break in a New engine..
    Started by monjarassi, 11-25-2013
    01-10-2014 Go to last post
  5. Sticky Thread Sticky: Engine Assembly Lube types
    Started by monjarassi, 10-18-2013
    10-18-2013 Go to last post
  1. Engine rattle when starts
    Started by sstream, 07-19-2016
    07-27-2016 Go to last post
  2. Exclamation a3 to a2 vtec setup questions!
    Started by AcuraJoe, 11-03-2014
    11-04-2014 Go to last post
  3. Cool IAC Valve w/ V-TEC Killer Setup - Q & A
    Started by dkpr87, 05-07-2014
    2 Pages
    1 2
    05-07-2014 Go to last post
    03-03-2014 Go to last post
  4. Cast vs forged pistons
    Started by monjarassi, 11-24-2013
    11-25-2013 Go to last post
  5. Why block off oil squirters
    2 Pages
    1 2
    11-24-2013 Go to last post
  6. Timing chain 101
    11-17-2013 Go to last post
  7. Plastic Cowl modifications?
    Started by echo3gulf, 10-28-2013
    2 Pages
    1 2
    11-15-2013 Go to last post
    11-07-2013 Go to last post
  8. O-Ringed Block
    Started by vdubkilla, 11-05-2013
  9. Buying A Used K-Series Motor?
    Started by Si Speed 317, 11-02-2013
    11-02-2013 Go to last post
Forum Information and Options
Moderators of this Forum
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 15 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
